mate its your daily that makes you look old....lol and dusty
didnt you see the memorial post, the dato's dead. passed away month ago. rusted and busted
n i call you chicks feisty felines atm :P
Edited by Inline 6
lol more random plans outa you, depends on what the engine is what you putting it in me thinks.
swapping a l28 in a l26 dato would be a sinch, but dropping that rb26 in my dato might take some custom work me thinks :P
engine mounts fuel injection alterations, blowing the welds on intake
Edited by Inline 6
who knows how to do a engine swap? how long would it take?
Just the engine complete with box. About a day depending on your tools and skills.
Including changing loom, ecu etc ... f**k that!
RB25DET Neo
When you said you wanted something powerful from me ... I didn't think you meant my Neo motor! :P
In that case, you'll need the loom and ecu as well won't you? As above: f**k that!
Engine swap itself will be easy ... with a hoist.
Edited by RubyRS4
see if john can do it for you Cara, workshops have the required tools and knowledge to do it all in one go for you
go T51R SPL with a small supercharger for that down low response :P
yeah i know damo but its still gonna cost abit in labour if i get him to do it for me, if i can get the engine in and everything i would like to just have to take it to him for tuning.
loom is pretty much the same at GTT and i got a power fc which is for GTT anyway :P so i think i should only have to get FMIC and boost gauge?
You might find there are a few add-on bits on the turbo version of the Neo
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
