mate its your daily that makes you look old....lol and dusty
didnt you see the memorial post, the dato's dead. passed away month ago. rusted and busted
n i call you chicks feisty felines atm :P
Edited by Inline 6
lol more random plans outa you, depends on what the engine is what you putting it in me thinks.
swapping a l28 in a l26 dato would be a sinch, but dropping that rb26 in my dato might take some custom work me thinks :P
engine mounts fuel injection alterations, blowing the welds on intake
Edited by Inline 6
who knows how to do a engine swap? how long would it take?
Just the engine complete with box. About a day depending on your tools and skills.
Including changing loom, ecu etc ... f**k that!
RB25DET Neo
When you said you wanted something powerful from me ... I didn't think you meant my Neo motor! :P
In that case, you'll need the loom and ecu as well won't you? As above: f**k that!
Engine swap itself will be easy ... with a hoist.
Edited by RubyRS4
see if john can do it for you Cara, workshops have the required tools and knowledge to do it all in one go for you
go T51R SPL with a small supercharger for that down low response :P
yeah i know damo but its still gonna cost abit in labour if i get him to do it for me, if i can get the engine in and everything i would like to just have to take it to him for tuning.
loom is pretty much the same at GTT and i got a power fc which is for GTT anyway :P so i think i should only have to get FMIC and boost gauge?
You might find there are a few add-on bits on the turbo version of the Neo
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
