Very interesting. Now you've got me looking at all sorts of demographic vids on youtube. Just as I was about to get of the comp.
Have a look at that./ Its not as detailed as the original but its interesting
yeah that's certainly interesting, very
front mount is mostly mounted. gotta get a couple more brackets made up, and clean up one of the elbows, but i should be able to get it all done and have it driving by the weekend.
Edited by scandyflick
oh yeah, andrew came over and picked up the dump pipe gear, good god his car sounds tough. probably the coolest sounding rb ive ever heard.
True, and it goes like f**k too... when he can get traction that is! :)
Hope you get it sorted before the weekend :)
Well, my PS3 is giving me some sort of Error code. After a quick search of the internet its Sony's version of Xbox 3 ring of death and the best part is, its just out of warrenty! Gonna ring up Sony tomorrow and sort it out, Hopefully its not going to cost me hundreds
hey mate what error is it?? ps3 has a common flaw with yellow light of death and the blu ray disk reader cracks the shits. and if its out of warrenty then i hate to say it but ur in strife, there not like microsoft and recognise that there is a major issue with there SKU's. best bet is to trade it in at eb games, they give you good cash for em. take the money and go buy another one and buy the 5 year warrenty...... very well worth it. might cost you all up around $200-$300, but you get a new console and a 5 year warrenty :)
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
