i said hi to Anthony this arvo for ya mr THE SLED :) He still remembers you and your gtr
haha, ole Anthony Chucky Norris is a good lad....I reckon Adelaide Engine was his very 1st job, when he was just a snotty nosed little kid.
Has he kissed and made up with his brother yet?
yeah nice looking "R32" there .... and it's non-turbo ewwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
Lmao.... not only does it say r32 GTR when it is clearly a R34 gt they quote the engine size at 2.6l non turbo. I was TOTALLY fooled. Definately a GTR... this is on my must have list.
7 psi i think i read was the max u could do on the stock internals.
but the learning experience in doing a DE+T would be good!
go thicker gasket to run more boost? it'll be safer as well
but i quite liked your first intial idea of going for the tomei 2.8 kit! it could've really been a real weapon with the right cams
I don't think so Pete. I made the mistake of calling his brother "Anthony" a few weeks ago and he didn't look impressed :(
He understood it was a genuine error and didn't think I was taking the piss.
Spent the morning getting of a small hangover.
Spent the arvo pulling all my FMIC piping off and replacing all the clamps. Still waiting on the silicone reducers, but I'll keep using the old ones. Lex has bought my old fmic kit (including piping, clamps and reducers) and he's been patiently waiting for me to get the whole kit together.
Weekends are never long enough :)
LOL, I can see where this is going......"headlines"......."BLUE MESH, it's more than flyscreen, it's a way of life!"
hahahahahaha nice work Pete!!!!!! we should get a sticker made up for Ruby so he can put it on the Stag :)
i wonder how hard it would be to fit one of these bad boys under the bonnet of the 31
Mack RM6-285 - 11.3L 285HP inline 6 with 285hp / 1150Nm torque
probably difficult, but more important - do you want to use 31 for towing lol?
Edited by Rocky88
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
