was driving at malala and car revved to about 6k in first before i shifted then it hit about 5k in second without the power kicking in..was really loud :) after that little dilemma now my engine bay smells like burnt rubber and when i change gears,it just doesnt sound like what it did before...
wondering what happened, any ideas?
fixed for ya :bunny: sure that it aint wheel spin u smelling or did you mean u took off normal and reved to 6k not a clutch dumping
and andrew its 138hp of oldschool muscle, who could handle the l26 monster :bunny:
those burnouts are not my doin but it is a regular spot for commos. cops actually go down there every now and then at night waiting for them to attack.
Edited by Inline 6
sooo.. I just got defected..lol. I sold the skyline to get away from cops, but still managed to get pinged in the shitbox. Least i can laugh about it this time, but i really should pay more attention to my tyres.
and to add on from this we could really use a good pair of 14" tyres. Size not fussed aslong as they got good tread.
yeah im with Craig on this one cooked clutch
ive got no idea when it comes to mechanics and all, but i did have a guess it was either the clutch or the turbo/s (r32 gtr). it still drives relatively ok, need to put alot more effort in shifting and taking off (like just from stationery).
any advice on replacement soon? or is leaving it a bad idea?
Yao
p.s. thanks to craig and madaz for the advice
i recommend buying a 4wd and getting it dirty
if only i had a few g's saved up...
the ORC twin is like 2k far out...
might look into something a bit cheaper haha
expecting around 800-1k hopefully, thats a couple of weeks pay
the NPC HD 5puk ceramic clutch good for 350rwkw or little over 300AWKW will set you back around 580 delivered and Daryl from Adelaide Radial Tyre will fit it for you at a good price $350-450 cant exactly say how much every job is a little different
you won't be able to run the suction cap ones at the track anymore. CAMS changed their ruling at the end of last year, infact you aren't even supposed to run anything other than lipstick cams anymore (but they aren't enforcing that at this stage at mallala, and are still allowing handy cams), and if you do run a lipstick cam the brace to hold the computer (that you need to run when using a lip stick cam) must be able to hold the computer under 25G's of load.
What i used was a L bracket that you can find at any hardware store and fixed it to the top of the passangers side seat belt (i.e. the seat belt mounting point near your shoulder)
when im on the track next time ill talk to the guys there and see what they say about the suction cup camera's. its not for any events just practice.
hoping to see all the things i should of done to do things better.
i see heaps of people using them this year so hopefully they dont care so much at mallala
call smooth garage.
niko and benny will hook you up an awsome price for a heavy duty clutch.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
