Life Story entry #319: thinking of going to the Blokes Expo this weekend.
Who else is intending on going to the Blokes Expo this weekend at Wayville Showgrounds?
:P
Yeah i am thinking of going out there and having a look see
whats the bloody point, theres no chicks there
I think you will find the complete opposite on this expo Dan
just in case anyone here is interested...http://www.nissansilvia.com/forums/index.php?showtopic=389082
Ya can't sneak it in that way ... its gotta go into the for sale section. :P
bahahaha nice try i would say that the mods would be onto this.....take it to the FS section mate
cooling pro? have fun fitting it.
ive had to remake all my pipes, either because theyve had huge welding dags inside the pipes, have been too long, or have been bent at the wrong angle, on top of having to make my own brackets, replace 2 silicon joiners, and source my own bolts and spring washers. all with the following response from jjr; "you get what you pay for."
Damo's kit that Jenkies and me installed went in ok, cooler pipe just rubbed on the fan a little. Intercoolers are about the only cheap parts i would fit to any of my cars.
No too obvious, but maybe it was so obvious that he got one, knowing we would think it was obvious and come to the conclusion that he didn't, when he actually did.
Confused yet? :mad:
Hint: its not a volvo ... its not a brap brap!
It has 4 wheels and 4 doors ... and a turbo!!!
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
