i see all. i am Morpheus
You know the best things in life arent for me
You know the best things in life, arent for free
Everyone of you could be the same
Everyone of you could play the game
Got a new life, got a new plight yeah
And its going nowhere
-D
question do i have the most boganist family
i have aunty her and her partner both have special edition peter brock vl's that are pride n joy. they named their kid BROCK (destined for a good life kid)
another aunty has a her house so full of crap she blocked off 1 of her hallways to store more, you have to walk around the long way to get to bedrooms
this is what happens to you when you grow up smoking too much weed kidz :) enjoy that happy tree kidz it will be ur demise
Edited by Inline 6
not taking any sides here, but in a car you can turn the steering wheel 45 degrees in a split second just before impact......you try that on a bike and you go high side over the handle bars with every chance of spearing the ground head first :)
only if you gota ride on bus like sled, heard it was the commo of the bikerboys world ;) burnnnnnnnnzzzzzzzzzzddddddddddddd
in irrelevant newz, my brother after a failed attempt at importing a car has instead decided to import a jspec yuki.
No thats not a japense bike apparently he's picked up
and vu stop worshiping your false vtec god, variable valve timing might improve fuel economy but my care factor is low when flying past your ass in my 1.6L pulsar monster
Edited by Inline 6
Awesome. i hear Japanese girls make the best wives. Whats her FOB price?
ewwww.............
side effects of being pregnant hey? :cool::)
Icing sugar on popcorn is awesome!
Just changing subject a little here.... Did you end up getting those quotes on the Motul oils?
Sorry if I've missed it earlier in this thread :)
Does not come with warranty, no English manual, not sure if she go’s hard – will not be testing either. May complain about the heat often but you wont understand the Japanese so best to ignore that problem.
$2,000 plane ticket uncomplied
Appears to be free from defects, will not need to go through regency but customs may require a check.
vin diesel quote
for those that respect fine body work no matter what the make
alternate fnf qoute
why dont you get a nice japanese girl like the rest of teh gaijins around here
hey if you marry someone they get half your assets right but does that work for liabilities as well? Cause they guy has nothing but a huge debt n no assets, maybe he could palm half off :)
and tablo how you change the topic of wasteland its random dribble
Edited by Inline 6
So far Repco came back $230 cheaper then autobarn on gear 300. Cant remember the other prices, got them written down somewhere. Gonna see if i can get them cheaper else where.
No worries. I'm not desperate for the gear oil yet but I want to do an oil (engine) change pretty soon and am still debating whether it's worth spending the extra on 300V over 8100 xcess.
I'm bored shitless at work and have plenty I can be doing at home :)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
