post-31501-1245326290_thumb.jpg post-31501-1245326348_thumb.png post-31501-1245326354_thumb.jpg
and so peace returned to the peaceful village that is SAUSA, hard battles were fought, loud words spoken, 1 casualty lost and through it all they learned something more about themselves about each other.....together they moved forward as 1 united sau working in harmony towards getting through the troubles that lie ahead. with the dangers on the horizon of a pending "yellow stickers" attack they will need each other please go learn some manners ted you fool
Edited by Inline 6
And so, peace returned to the awesome village that is SAUSA, hard battles were fought, words were thrown, no casualties suffered amongst the allies and the demon was vanquished. Through it all, they learned something more about themselves and each other.....together they moved forward as one united. SAUSA continues working in harmony towards getting through the troubles that lie ahead as demon scum's minions remains at large awaiting for their leader to once again return.
This one was better :D
dude im trying to be serious here and tell a friggen story begging middle ending and you f ing it up turning it into a joke, this aint no comedy mofo.
on a serious note this had been prob the most lol's ive eva got outa sau as of late :D nearly 24hrs of lols here
at the pga day i made 130ish with a exhaust leak and a slight misfire. and that was just with the catback. with 5psi more boost, turbo back exhaust with hi-flow cat and the front mount should make a tidy improvement.
Edited by scandyflick
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
