Cheers Pete, it does feel good! :D I have to thank you the most, they are your turbos after all! :rofl2: Just a shame I had some gremlins stopping me from running full boost, would have broken 320kw me thinks
Dave, yeah it does sound good mate, pity you didn't hear it on the rollers, hit up my facebook soon though and you can see the run!
anyone get defuct last nite at lofty?
a couple of my mates got done by unmarkers :)
yeh i got a msg from mitch last night.. was gonna take the rolla for a strap but thought twice!!
must be mass cop heat atm!
welcome to the 300 club buddy boy
yeh welcome to the 300 club Luke
awesome power curve on that dyno sheet u got there. welldone
also god to see you went to Morpowa, Simon is a GREAT bloke down there and very helpful
how does it feel on the road???
ACTUALLY... I ended up going to Shaun at boostworx ( long story, I know I changed my mind more times than I changed my undies :) ) but I'm very impressed with the power and it's delivery. Feels sweet as on the road, struggles a bit for traction though, putting the front shaft back on tomorrow when I get her on the hoist. Simon commented on the tune, in his words "perfect" Couldn't get any better praise than that. I think he wanted me to move to E85 though :P
what was the "knock" reading if u dont mind me asking
Well, the results are in if anyone cares... Had a boost controller issue, only able to wind 16psi into it but still good numbers!
Noice! Well done. Stuck with 16psi ... what were you aiming for? 20+?
I'd be happy with 200 out of the Stag when I'm done.
bought a new family car today, not a skyline/stag sadly, but decent none the less.
got a 2000 Holden Vectra olympic edition in metallic blue, 107k power everything etc.
they where asking 9999, managed to screw them on a 4 k trade in for the 99 auto 1.5ltr lancer..hehe
so $5999 cash on top of shitty lancer, im happy with that.
20 would be the MAX, more like 18psi. Either way I'm happy with the results
I am hopefully going to be getting 250rwkw or above out my R33 around September/October time.
Fantastic power mate, MORE than plenty really. After driving the R around in RWD mode, you realise just how much 300+kw is. 250 is a very respectable figure
Should've read "stuck on 16psi" not "stuck with 16psi" ... not like you had a choice by the sounds of it.
Obviously you ran it on AWD. I'll be squeezing my lemon later in the year to see what I can get out of it ... in AWD also (and a manual box conversion).
I recall Ben (Grim) passing comment to run 24psi in this stag eventually. Be interesting what he gets out of that "family wagon".
Edited by RubyRS4
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
