Should've read "stuck on 16psi" not "stuck with 16psi" ... not like you had a choice by the sounds of it.
Obviously you ran it on AWD. I'll be squeezing my lemon later in the year to see what I can get out of it ... in AWD also (and a manual box conversion).
I recall Ben (Grim) passing comment to run 24psi in this stag eventually. Be interesting what he gets out of that "family wagon".
Yeah, stuck on. No choice, still happy but
@Ryan, yes, yes you do :)
Guys, my car is still up for sale...It needs a good owner...It's sitting in the workshop all lonely. :)
$18990 Might wack it up on Carsales soon.
I NEED a GTR.
im so tempted by that. its almost retarded.
So whos gonna join me in the 400kw+ club next year? I cant be the only one.
Is this 400kw+ in drinking booze?
No one can compete with you there Luke :) You the champ.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
