your car has stickers cara you dont want none of this, and dont get me started on the blue mesh 1 and front bumper speed holes etc.
btw we getting a new wasteland thread soon? this 1 is almost 2 years old.
time to move on me thinks :laugh:
your argument is still invalid dan :P
Ok i purposely signed out of this thread due to all the shit in it but i will post this as i know a lot of you guys love your face book
Warning from symantic this morning about an email getting around for you to click a fb link and sign in DONT, even be wary of links from trusted users and for the moment dont click links from fb emails open your browser and login to fb manually to read emails /signing off again
the blonde chick cop on channel9 missing person unit could cuff me anytime,innocent or guilty
+1
Was watching "Recruits" last night. That recruit chick in that show is thick as. She's such a princess ... too far in love with herself to take the job seriously.
Speaking of stickers, will there be SAU:SA stickers made? Just small one to put on top of the front window? Ill be joining at the dyno day.
We are currently going over the options for the designs. Please be patient.
Weezy, and anybody else, PM me your email addy and I'll send you the membership forms. :)
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
