Me too!
I cant say Ive seen those rims before as they appear to be stock? Although dont some Stags have something similar? Thats what my steering wheel looks like :P
That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
how much for neo coilpacks Andrew?
lol sorry Dave, I'd hate some bandit to come out of the woods and accuse me of not sticking with the "rule for one and one for all" deal!
Remember, I've got double standards :P
well you ride a SLED and a TOYOTA and your a mod for a NISSAN SKYLINE site
how much of a double standard do you wanna get Pete :D
PS its a joke.....dont hurt me :P
what happened to you pete? you used to be cool. you used to be all about the favouritism.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
