anyone know wat ecu i can go for seeeing as i cant find a CA18DET PFC?
and to lock my diff :(
cheers
Anything wrong with a remap?
It'll do everything and more that a P-FC will do (infact it is better as it retains the knock control that you lose with P-FC) with the exception of the hand controller and if you want something like that just pay $400 for a NIStune board and you can plug it into your laptop and bring up more info than the hand controller will give you.
Edited by D_Stirls
I've never been told off before :)
They only tell you off if by sliding you are going to b causing others to crash into you....which can build up to a massive pile up and many karts being broken lol.....best effort in breaking karts at an event so far has been 3 for my events
it aint how you stand by your kart
ive never been told off either including the 1 time i lost it trying to get it 2 far swideways :(
motivational pics
Good motivational pic there Dan
If anyone is after Motul Gear 300 75w-90w 100% synthetic gear box oil i have a 25L drum of the stuff. I'm selling it for $32 dollars per litre. In shops this goes for $43+ per L.
Let me know here or via pm if you need some.
Might give you a yell soon Luke, gearbox is well over due for fresh blood
Let me know when your going to get that coz i will most likely need this done to my line as well
so, im lazy and have only just started searching, but i figured id ask anyway...
... anyone know where i can find ecu pinouts for the s14?
Try NS bro
andrew just gave me a call, he's coming by this afternoon to mock up my t/b intercooler piping, and expects to have it ready by tomorrow arvo. :)
Try NS bro
found it about 10 minutes after i posted. :)
well...after sunday's fuel tank issues...monday saw the car struggling to get fuel which saw me creeping up south road towards junkfood corner at 5km/h :( ....the wife took the pump out while i was at the chiro and i found a few clamps loose that were holding the 040 into the stock cradle...moved the pump up and tightened the clamps and test drover...problem solvered.....so i thought...going to work the next day and was getting surge issues and the car was backfiring and carrying on like a pork chop....took the pump out last night..then went to my mates place to pick up my old "holy" tank to get them side by side..the tank i'd bought was out of a S3 R31...my tank was the same on the outside but different on the inside...so i went to my mate that i bought the tank from..and had a look in the back of his S2....exactly the same as my old tank.....There lies the problem...mine is an early 88....one of the first..so it carried on some of the S2's parts....including the fuel tank :) ....tonight im going to grab the tank thats in his spare car...and friday night swap them over on the hoist at my other mates shed over a few bourbons.......Damn skylines!!!!.....Bloody vintage car...
THE END :):bunny::):bunny::blink:
God I love it when you ghetto repair some drift damage and it actually turns out well :P
Munched the front corner of the sil a few nights ago. Nothing major just a bent guard, scraped front bar and parker light was MIA.
Bent the guard mostly back out, masked up the lights and gave her a quick spray and from a distance you almost wouldn't even pick it :D. Just chucked one of those crystal parkers in there (gay looking thing) for now until I get another stock one from JIS tomorrow - then it should be almost back to former glory :P
Now to make sure I avoid Clems tyres on satdy evening :(
geez, this day is dragging on! anyone got any cool shit to post up?
Your not wrong there Damo.....i thought the clock said 4:24pm but that motherf**ker is saying 3.24 now....this is just not right
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
