pfft public.....how's about having in the collection...a 1/8th dirt dragstrip with a 1/8th runoff...making 1/4 mile all up....a dirt drift track....a minibike track......concrete burnout pad....boonga racing track complete with viewing tower with lounge suite....border motorbike/quad track......shed space which equates to three 60x40 sheds next to each other....camping grounds for tents and caravans...2 permanent caravans...plus a massive 4 bedroom house first built circa 1900's......plus "the road"....and enough paddock space for five cars to be doing circle work at the same time.....oh and a bonfire space that when cooking, can be seen from the port river expressway.OOOOOOO YEAH!!!!
whats the deal with the manual boost controllers u can buy?
i thought with all your experience with turning.....you would know :bunny:
just make sure that you dont put it up too much as it can then run some crazy boost and before you know it either the turbo has gone bye bye or the motor
Edited by Krishy
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
