EBC's control boost & make the boost come on alot more harder then a T Peice will and defeinatly control boost spike especially if your looking at holding decent power where 1 - 2 psi extra will cause your car to detonate and end up smashing pistons.
If you can afford it and are looking at running more then 10 - 12psi a EBC is definatly the thing to buy.
Buy a apexi powerFC boost controller that works in conjunction with a powerFC if thats the ECU your going to be running, stealth as, its easy to hide the boost solenoid in the engine bay and can all be controlled using the hand controller or laptop via the tuner I think,
Thats what I am going for anyways. I will have a bleed valve forsale soon if your keen Cara - Its a turbosmart one lol
EBC's have flashing lights!!!!
oh how exciting
JK has said to get a ebc......but i not sure whats the best for what im doing, ive seen a turbosmart single stage boost controller....would that be ok?
turbosmart eh? hmm, last i looked into turbosmart, well... yeah. say no more i spose.
once i get my hybrid tuned, ill let you know how it goes.
i dont think id be runnign anywhere near 12psi anyway
maybe only 7-8psi
or, you could get a DET and run 12psi.
You don't need a boost controller for 7psi >_>
+1 what he said
actuators come in all sorts of settings but I know that 7, 14 and 20psi are rather common
i have stock gtr with stock turbos but the ebc lets me run to 14, and when i get my n1's I'll be able to go to 20 no sweat
if you're running steel turbines I don't see why you wouldnt be running 14 at a minimum (unless the neos cannot hack it? I wouldnt know tbh), and if you are going to run 14, the ebc will make a noticable difference
-D
She wont be able to fun F all boost cos the engine is an NA with high compression, I think even 7 psi would be giving an NA a pretty hard time.
fair enough. consideirng the 25det engine + loom isnt that pricey, the det does make sense considering the cost/hassle to fit the turbo onto the NA
-D
ive decided that my soldering iron sucks.
EDIT: not to mention references to "African Americans"
LOL, you're asking for a stick up your bum Dave
it is possibly that may have too much bad language... hmmm...
Edited by SLED
Dohmar - Where you getting your turbos from and what price are you looking at?
Can you PM me. I will be doing the same very shortly I hope lol :D.
Lmfao, I love it Dave!
Edited by Weezy
HAHAHAHAHAHAAHAHAHAHAHAHAHAHAHAAHHAAHAHAHAHAHAHAHAHAAHAAAAAAAAAAAARRRRDE HAR HAR!!!! funny funny stuff.......also...LAST DAY B4 TWO WEEKS OFF!!!!!! WOOOOOOOOOOOOOOOO......i'll be up at my mates shed again tonight....fitting my fuel tank so i can actually boost again...havent been sideways all week......i miss my boost
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
