Dohmar - Where you getting your turbos from and what price are you looking at?
Can you PM me. I will be doing the same very shortly I hope lol :D .
Lmfao, I love it Dave!
Antimatter is building them for me from a set of blown stock turbos that I purchased. Costing around the $1700 mark with new 14psi actuators
-D
I think 34's and 32's look hotter without any wing and as for 33's well that gap with the boot and the car makes you have a wing
34's, from behind, look like a farkin rectangle without a spoiler. Spoilers give them character, without a spoiler its just a normal street car
+1 Definitely!
It's all personal preference I guess but I must admit that I've never really come to terms with why guys de-wing R33's and 34's. To me it's the same as some of these guys who actually spend money on gay body kits and wheels (they're not all gay though) to make their cars look worse than a factory standard car. Each to their own however.... :D
IMO the only one that gets away with it is the R32 GTSt's.... 32 GTR's, all 33/34's must have factory wing
Dang, so my 34 that I have de-winged is gay? *sob, sob, sob* Ah well, hope somebody buys it anyhow :down: .... ask your mates guys - she is going up on car sales next weekend for $21k .... 230rwkw and lots of fun to be had.
My new Nissan has a rear wing :D:O .... I fly to Melbourne to pick it up July 18th now ....
Sorry should have put more emphasis on the 'personal preference', 'each to their own' and 'IMO' parts. :down:
Without back peddling either I was also referring to coupes and honestly I've seen your car twice now and I think it looks pretty fkn tough for a 4 door and I'm not saying that because you're a mod cause I'd rather say nothing if I thought differently :D
Pretty tough time to sell a cars it seems, mate with the Evo X has had to trade it on his next purchase!
:P:wub: u know we love you long time penny :P
i aint seen yours yet, i am unable to comment. i dont think 34s are that bad. hell id hit that from behind.......wait a min what were talking about...........o yeah. i think worst without wings is 33s and nsx's cause they have the bit thats higher on the outside of the boot with nothing to line up against once the wing is gone
Edited by Inline 6
+1, i couldn't de-wing my 33, just looks wrong.
I do however favour the aftermarket d-wing. i have one, been sitting at home for ages. but something has just been holding me back from ripping my standard wing off... its the s1 rounded wing - many prefer the s2 wing from what ive read in several threads. but i reckon it marries well with the other s1 body parts.
+1 for the D wing/bootlid spolier/duck wing whatever its called....makes the 33 more complete i reakon....i have mine on its way from brissy so that will be going on sometime soon
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
