got my cooler pipes today. they look mint, andrew did an awesome job. forgot a holesaw though. :)
got a bit of wiring and a bit of cutting to do, but its almost there. will post pics when its all back together.
Awesome! He does great work, I'd love to see some pics of it now
Have fun getting the holesaw through the inner guard, i gave up with mine and attacked it with a 1/8 drill then belted it out :(
haha. if i get frustrated and give up, i can get a pneumatic drill and a tungsten hole saw at my door within a couple hours for nothin.
that he does. but im gonna make you wait. :)
might swing by when its running tomorrow.
Edited by scandyflick
ladies and gentlemen, i have two words for you;
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :yes:
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :D
scratch that. problems already. hit a little over 1bar for a second on a test drive, pulled over straight away and readjusted the controller, problem is, now it isnt boosting over 0.5 bar no matter what i do, and it hits a wall at 5k rpm. :thanks:
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
