:thumbsup: Decision made then!
See, there's $400 saved already. Only $1600 to front up now. Sell your body on the streets, you'll only be looking at another $1590 or so after that, every little bit helps
lol. ive got til monday or something to make a choice... i dunno. ill see how much the tax man wants to give me and go from there.
hahah.
two chicks from my school were strippers too.
get this :
Both underage at the time. 17 each.
One was at crazyhorse. the other was at 108s. or whatever it was called.
Was in the paper. big trouble.
lol were they twins? might be same 1s
Calling Chad, calling Chad......where are you??
Are you anywhere near my house tomorrow?
Need some welding advice bud (gates & RSJ's for a retaining wall).......would get my Dad who's a Boilermaker but he's fallen very ill unfortunately.
I'm starting work at 6am tomorrow, so i should be finished work by about 3ish. I'll give you a call when i finish and see where your at.
Dave go for a GT28RS, if you keep the boost below 12 psi you can get around without a tune for the time being. I would just do a run on the dyno to see what the AFR's are like though before you push it too much, but that'll only cost you $50. There is no point rebuilding the T28 when you will only get $4-500 when you go to sell it. you might as well put the rebuild money towards the GT28RS.
A 2871 is a bit to big to get around on without a tune, you would have to keep it below 9 psi and it would be dowie as and you wouldn't like it.
What are you still doing up homo?
resetting the body clock for nightshift.
rebuilds only costing $450...
how much does a 28RS go for anyways?
well stock cars are welcome to join in with the club displays - you dont have to have a car that is a show car to be part of it all :rofl:
ok so let me know when something comes along and we will see if we can make it.
only thing is the car needs new coils so i dont want to drive it realy far until thats done :thumbsup:
he he i got in trouble for spending $300 on headlight globes :P supposed to be paying for a wedding
only thing is the car needs new coils so i dont want to drive it realy far until thats done :(
he he i got in trouble for spending $300 on headlight globes :) supposed to be paying for a wedding
dont wanna buy some standard springs and shocks by any chance? :blush:
btw Talbs, i beat you in dream team last week :blush:
Did I make it into that group you setup? I should really go in there and see what it's all about, at the moment I've been just trading players.... and congrats I didn't know you beat me :(
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
