back on the hunt for a turbo. the bb i was gonna buy is apparently plain bearing...
That's been for sale since the dawn of time
longer than that i think.
clearly not phased about glenn
haha, buy ryans, 300rwkw...
:edit: wtf at the exhaust on that purple 33... :)
Edited by scandyflick
saw the exhaust on the purple one, like the modding of the bar to fit them
saw that white one, has all the gear but a bit to expensive me thinks
going to look at said auto one tomorrow morning with luke, hopefully as clean as it looks and stops raining while we are there
gtir's are great for an sr20, i think mr pickering has one for sale?
yeah, done a quick bit of reading, apparently theyre a pretty stout little bit of gear. good for 230-240 from what im reading.
he does? got a link? i know he was selling a hks gtrs some time ago...
only thing worrying me in the stall converter, not really daily friendly, hopefully someone wants a build auto box (cost him 4500....eeek)
ouch. $4500 for the auto? f**k me.
i think mr squiggle made a mess on ur face luke, we got photo proof if you would like to drag it up again :woot:
:) owned. lol
Some cock tried to steal the 33 on the weekend. :down:
A club lock and alarm kinda ruined it for them :laugh:
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :)
:) i just cant help myself ruby.......i gotta stop coming round to your house all the time hey :P
I'm not gay, the guy who feels me is
oh dear..... :)
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
