I am undecided. I have tried it but I dunno how I feel. Ill give it another lash tonight....
My first experience wasnt so impressive, this must be how it feels for people trying vegimite for the first time.
The new vegemite is shite inho - Damo is exactly right - they have dumbed the flavour right down to sell o/s. It doesn't even taste like Vegemite anymorew - where is the harsh bite/tang we all know and love?
Oh and Damo, sorry to tell you mate, but the cover I bought directly fits like 6 different models of car, and can be slightly modified to fit another 10 or so :D
So, what is your guess?
a garrett gt3076 turbo will NOT make 320 rwkw!!!!!!!!!!!!
the bigger gt3040 with .82 rear exhaust housing will only just make above 300rwkw and thats on a forged engine and thas with external gate
Thank you for clarifying that for me mate. So what should i get to be making around about 270-300 with nice response. Happy with pretty much anything over 250rwkw
Good morning everyone!
Im already bored.... this Iced Coffee strong is making me freezing.
Good Morning Penny
I would love to share the iced coffee with you but no i dont like it.
It tastes like Instant crap mixed with milk. yuck
What the hell is with the non iced coffee drinkers here?? its very unAustralian!
On another note if its a nice freshly brewed coffee then i am all up for it.
i dont enjoy any type of coffee.
Damo GTFO if you dont like coffee :thumbsup:
VN Statesmen Andrew?
Thats way too much class there bro...I am thinking 3.8ltr VN exec :D
^^^ Krishy got owned!!!
I hate vegemite too and I drive an import (not a holden) ... so I'm just following thru with being un-Australian :D
Edited by RubyRS4
Was gonna go look at a car tonight, goddamn, owner lives just south of Hackham :S hour and a half for me! Anyone wanna do it on my behalf? :D
thats like 5 minutes down the road from me (port noarlunga)
i might do it depending what car it is :thumbsup:
you plebs need some culture.
So here you go!
Looking Out
Across The Night-Time
The City Winks A Sleepless Eye
Hear Her Voice
Shake My Window
Sweet Seducing Sighs
Get Me Out
Into The Night-Time
Four Walls Won't Hold Me Tonight
If This Town
Is Just An Apple
Then Let Me Take A Bite
If They Say -
Why, Why, Tell 'Em That Is Human Nature
Why, Why, Does He Do Me That Way
If They Say -
You wouldn't want to be around me in the morning if I skipped my coffee..... :D
Same here man....coffee i mean good freshly grounded up beans and brewed properly is like nectar of GODS....
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
