18x9 +20 and 18x10+18. I seen the car your getting yesterday with some CE28s but in a smaller size.. Looked okay but no where near as much dish as XD9's. There is nearly 100mm of dish on the rear!
how much for said rims?
dang, that's right .... there is no way they would fit .... the rears are 65mm wider than stock - they would hang about 3cm out of the guards :) .... 33mm wider than stock is the perfect number I am after, so 10" rims would need to be offset of +50
Yeah the CE28Ns I have priced and chosen don't have anywhere near as much dish as I would like, but they will have about 35mm dish which is the best I can hope for with this type of car.
EDIT!! Damo beat me too it
wheels on the Stag are already porn, 19" Racing harts FTW!! I was thinking for the 32, over the 34 rims now.
ATTESSA will chuck a hissy fit if you run staggered widths because no matter how hard you try you won't be able to achieve the same rolling diameter.
Don't believe me have a play;
http://www.1010tires.com/tiresizecalculator.asp
Edited by D_Stirls
because of the different stretch you will actually be running different rolling diameters so you will be slowly killing your clutches, the good thing is because the 32's don't run any preload you won't be wearing them as quickly as you would be with a 33 or 34 that run a proload.
Edited by D_Stirls
anyone know of a plastic welder in sa?
yeh i do mate
BUMPER TO BUMPER CRASH REPAIRS off tapleys hill road at Royal park
he did a great job on my series 1 m-spec bumper cutting out the middle section out and instead of leaving the cut out bit on the sides open he plastic welded a section in and it now looks flush
he is located in the western suburbs
Not cheap. So if your looking for <$2,500 no chance.
That's half the fun, making them fit. Camber might help tuck them in aswell.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
