went past turbotune today,closed with d's out the front.sorry to hear about your car mitch,that really sucks man.theives just show complete disregard for property that the owner works hard to pay for
dont club seals,club theives....bell-ends
CORRECT...........I still laugh everytime I see those signs, you'd think businesses would've learnt by now.
simmilar to the signs in retail/clothes shops saying you have no right to a refund or exchange after set time frame or just not at all. i see them all the time and its actually illegal to even show signs that claim to restrict your rights.
http://www.connectme.com.fj/node/246
no matter what you can have refund, exhange or repair at your choice if the goods have a fault from when you recieved the goods.
but then whos gonna bother spending the time to sue them, bored old ppl are too busy attacking the car scene at the moment :)
wow mitch i can't believe that they went through your car as well.....would be interesting to find out what has been taken out of your car and how mangled the interior is??? hope nothing got taken and they left the interior reasonable condition.....
I need to hear from the following SAU:SA members ...
Nismoid had issues with the following accounts:
Rodders211
lovemy32
Nugsy31
Rodney, I'm now aware that you've changed username to -RBD2-
Nugsy, there was a problem getting you on, but I think I found the problem
Anthony, can you confirm if you have a new username?
yeah im not looking forward to finding out ey
well , just got back home and im offically in tears
JVC Tv headunit is gone along with the remote for it , the snapped my dash surround in 100 places to get it out and had the decency to leave me the brackets to mount another head unit in there...
gear surround is smashed
greddy ebc is gone but the solenoid for it is in my shed
and they left me my turbo timer
oh and apparently its not covered by the workshop.
fml.
oh no thats some shattering news there mitch.....i feel for ya mate....the thing that i dont get is how is it not covered by the workshop.....the car was on their premises so its their responsibility isnt it?....thats like almost 2K worth of damages there man....hope somehow you can get it back from them.....
yeah thats it...when i got pulled over for spinning my wheels to avoid getting t-boned by some moron in a camry...there was still a listing of when i got done "tresspassing" back at least 14+ years ago when i used to be a stoner.....
please explain
i would if i could...
apparently my car has to have comprehensive insurance to be covered there and that their insurance doesnt cover it?
pm me if you like Pete
cheers Krishy :P
who says.......Dave & Mike??? :P
What if they only had your engine on their premises and it was stolen.......you can't comprehensivley insure an engine!
Speak to consumer affairs......your car was secured on private property, not driven on the road.
Yeah i will be Pete, im not going to let this slide.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
