Attn scandy;
How much was your turbo rebuild and hiflo and where did you get it done again? Looking at buying some N1's that are in need of rebuild cheap and sussing my options if its even worth buyin haha
your best (cheapest) bet is to find a pair of blown ceramics and sending them over to Antimatter in melb and get them rebuilt. Hes doing a pair for me at the moment (which i need to get off my arse and pay him the rest of the cash i owe him)
best thing is, if its in the original gtr turbo housing, regency wont know any difference
-D
i was reminded this evening why i rarely drive the s14 to work. people stopping dead in front of me at 80km/h in a merging lane when they have more than ample room to merge, ive had to jump on the skids because i dont have the room to skirt around him, and the guy behind me has had to spear off the side of the road, and the guy in front had the nerve to jump out of his shitbox and abuse me for 'not knowing how to drive.'
f**k i hate shit people.
Attn scandy;
n1's are bb yeah? rebuild kit is $1300 or something for a bb. dunno. could be wrong.
got it done through hypergear (check on ns.com), standard rebuild was $400, highflow was $800.
Edited by scandyflick
got thru it alright, will be ideal with a snorkel later down the track. had a steep old drop off on one side as you go in............got thru it easily, but dont trust my door seals that much to do it more than once
got an irritating as all f**k knock in the front left corner on right hand turns and hard lefts.
rather concerning when youre doing the uh... speed limit through the hills and you hear that.
any suggestions as to what it could be?
^ Hey Scandy.
It could be your wheels hitting the struts? or wheel guard... why that side? maybe it could be due you Adelaide poor camber roads :P
or... you hit the corner hard?
or a leaky strut?
hope that helps....
ps; SwineFlu sucks... a whole week off isnt as good as it seems, you sleep all the time and just plain bored!
Edited by AXTX
no leaky strut, checked that. plenty of wheel-sturt clearance, enough wheel-guard clearance for it to not be that (only scrapes on hard bumps), so im at somewhat of a loss. matty suggested it could be ball joints. seems likely. i reckon theyre oem...
You can buy brand new -5's for less than that.
Coils with camber tops? Not the spherical bearing in the top rattling? I had that with a set of coil's in my car drove me mad till i pulled them out when i sold them and found out what it was...spewing
How much man? I will have a daily soon so I'll just rip my turbos off and send them away if the price is good?
PM me if you dont want it on the forum.
You'll have to PM him for a quote for his labour and parts as Im not sure what the prices are like atm, and if you want to buy a pair of turbos I'll have my stockers for sale after the new ones are fitted, but we're talking a couple months here
-D
turns out the engine i bought off here has a shagged cylinder and bent valves -.-
i am so happy about this
jeez man ur run of bad luck just keeps getting worse
can you fix the cyl with a bigger diameter bore ? could be good excuse for 2.8lt pistons ? ;\
-D
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
