jeez man ur run of bad luck just keeps getting worse
can you fix the cyl with a bigger diameter bore ? could be good excuse for 2.8lt pistons ? ;\
-D
cant afford to man, i have $500 to my name and no car or job.
i think it might be time to sell and cut my losses :s
Just make sure you work out if that is a good option mitch.....i am pretty sure there would be a great demand for parts if they are going at the right price.....good luck mate
When can I ask for a refund?
You have a right to seek a refund if the goods you bought:
• are faulty
• are unfit for their purpose (they don’t do what they
are supposed to do)
• do not match the description or sample you
were shown
• have defects that were not obvious or were not
brought to your attention when you bought them.
You do not have a right to seek a refund if you:
• simply change your mind
• buy the wrong item
• fi nd the goods cheaper at another store
• use the goods in a way that they were not made for
• caused the goods to become damaged.
However, you may still be entitled to seek a refund
under a store policy, warranty or guarantee.
Seeking a refund
To seek a refund you:
• should return the goods in a reasonable time
after buying them and you must not lose, destroy
or damage them
• may be asked to provide proof of purchase—
the best way to do this is to show your store receipt
or credit card or bank statement which shows details
of the purchase.
You have the right to seek a refund irrespective of
whether you have proof of purchase. In practice, however,
it is easier for you to seek a refund if proof of purchase
can be supplied to the retailer, supplier or manufacturer.
sweet error message off the forums... when I searched for loxton...lol
The error returned was:
Erreur Sphinx : searchd error: unknown local index 'ipb_search_topics' in search request
Merci de contacter un Administrateur !
just in case you wondered what the whole message would be like in French:
L'erreur renvoyée est:
Erreur Sphinx: searchd error: unknown index local 'ipb_search_topics "en demande de recherche
and in Korean:
오류가 반환되었습니다 :
Erreur 스핑크스 : searchd 오류 : 알 수없는 검색에 로컬 색인 'ipb_search_topics'요청
메르 드 문의 유엔 Administrateur!
• are faulty
are supposed to do)
were shown
Seeking a refund
or damage them
of the purchase.
It depends on where he bought the engine from though, if it privite sale it's buyer beware.
Edited by D_Stirls
bout 10:30 til 12:30ish. Spotted Dan, Luke, Vu and Nathan there as well
haha, so you left about the same time i did.
it apparently died pretty solid about 2am, with most of upstairs closed not too long after.
so, that noise is still there with stock wheels fitted. slightly annoying. will get the guys at morpowa to check it out when i have it dyno'd on wednesday.
jack up the car on that side, support it tight...with the wheel on rock it from the top back towards you, does it click ? if not try to rock it from side to side, does it knock a bit ?
loose wheel bearings, worn out ?
loose tie rods, worn out ?
sway bar loose or bushings worn ?
loose wheel or mis tightened ?
loose shock tower on top or bottom ?
loose dog bone bolts on the calipers ?
the wrong lug nuts, not coned the right way for the wheels ?
hit the wheel with a kick or rubber hammer, do you hear rattles, loose brake pads, shims ?
all pretty common on nissans, could be a worn gear on the steering rack as well ? but not so likely
hope that helps dave
lol i got that a couple of days ago,
google translate says:
Translation: French » English
Thank you to contact an Administrator!
figured it was french,, I just like the
Sphinx'ter error..lol
translated into , "it shit itself"..lol
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
