yuk, too friggan salty
crumpets, better then pancakes but not as good as waffles.... the debate begins again...lol
how about french toast ???
eww at pancakes (unless from cafe primo...lots of cream and that other stuff :))............and WAFFLES WTF!
yanks. weak as piss. vegemite is awesome.
+1
they have no taste :)
I thought I was your best friend Dave? No more special hugs for you
youre my special friend luke. :)
Someone buy J-dawgs rims first tho lol.
id rather buy some 17x9 and 17x10 low offsets in wmb eh...
or maybe some 11r's... or those new ssr's...
yeah 16.8L left. Still got Krishy's car to do, and a whole bunch of guards to roll.
If your heading to the Dyno Day i'll bring a container with me, get you to fill it, and grab it off you later in the week if thats cool mate? Would be after 4ltrs
you can scratch me off that guard roll list. couldnt wait, ended up getting chris at tyrepower to do them.
http://www.motul.com.au/product_line_up/gear_box/gear05.html
It says dont use with cars with LSD. So maybe not. I'll have a look tomorrow what i used for front and rear diff.
Dave those 11R's are a pretty nice rim, they come in matt black :)
lol. nevermind. misread that. :P
just doing the sums now, 9 +15 should be sweet on the front. should be. 9.5/10 +15 on the rear should sit about where i want it.
Edited by scandyflick
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
