No, sorry.
Ummm guys, has anyone heard of any horror stories with bolt on spacers? I possiably slightly maybe be swapping my wheels but the offset on the new wheels is not enough to fill the GT-R Guards,
Anyone got any opinions? Swap will be for R34 GT-R wheels
No, sorry.
ask Chad he has some R34 GTR wheels on his car ? pretty sure they fill the guards fine
LOL Dale..........I look forward to AB361's response......if any.
BTW, you coming to the Dyno Day....maybe entering your beast???
Sorry Pete, i thought that the DD was in the 23rd not tomorrow so i guess i won't be making it in my car. Might make an appearance though.
Edited by D_Stirls
Unfortunately, my mate who bought it off me (and I'm subsequently buying it back off) resprayed it a yellow, red, green theme :thumbsup: and I'm going to respray it back to its original colours (as in the pic). I gotta source the decals from the UK again ... but thats okay, because the Tyga race system is coming from the UK also. I've got until Feb next year to set this bike up ready for next season. Might sound like enough time, but I'll be working interstate 3 weekends over 3 months and due to missing some local practice days at Mallala, that only leaves me 1 (maybe 2) track sessions for myself to test and tune it.
Speaking of bikes, I just saw something like this:
in a mag waiting for a hair cut. Limited Ed around $200K :D
the new GTR killer? 2009 Porsche 911 Avalanche GTR (lil bit o Nissan) 650 EVO-R (lil bit o Mitsubishi) by Gemballa
imo, it looks shit hot. but, not with the roof down:
This new creation sports a serious engine makeover including racing crankshaft, titanium connecting rod, forged pistons and racing turbo chargers. Airflow is increased via an aluminum induction pipe and carbon air box with a more breathable air filter. The result of these efforts is that the Gemballa Avalanche GTR 650 Evo-R is capable of 650 hp, sprints from 0-62 mph in 3.4 seconds and has a top speed of 206 mph. The sound this engine makes is truly phenomenol based on a new stainless steel exhaust system with racing headers. Gemballa isn't exactly set in their ways. If you want them to take the car up to 800 hp, that is actually an option as well.
Works out to about $595000 AUD. You could buy a 35 GTR, make it quicker and buy a house for almost the same coin.
OOPS.... I dont think Vin would like his gender change... always good to see when a major company farks up a web site
FNF 4 fark up
the actors names are labeled wrong... lol nice work
Ruby I have a timing light,, but not in the country... sitting in mom shed in Colorado .. sorry mate
Damn that Porche is a panty dropper .... drive that the panties would fly off for sure....looks like a stealth fighter ..lol
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
