i had one of those yesterday. f**king InDesign CS4 has chosen not to work, and its actually a legitimate copy!
Not condoning the use of pirate/illegal software of course, but I'd be guessing it would probably work :D
I want a busy weekend... think I'll drop round JIS and see if theres anything I can impulse buy. :P
Bit of automotive retail theropy, definatly works, I love buying sh!t for my car :huh:
A cop was on his horse
waiting to cross the street, when a little girl on her new shiny bike stopped
beside him.
'Nice bike,' the cop
said. 'Did Santa bring it to you?'
'Yes Sir,' the little
girl said, 'he sure did!'
The cop looked the bike
over and handed the girl a $5 ticket
for a safety violation.
The cop said, 'Next
year, tell Santa to put a reflector light on
the back of it!'
The young girl looked
up at the cop and said, 'Nice horse
you've got there Sir.
Playing along with the
girl, he chuckled and answered,
'Yes, he sure did!'
The little girl looked
up at the cop and said, 'Next year tell Santa;
The dick goes
underneath the horse, not on top
peel the rest of it off
you have a nice looking machine, turbo or not. those vinyls shit it to tears
i cant, im sponsered by DZignFX and have to leave them on until next year (feb), but im not sure what ill be doing next year in the sense of going graphics or not
No graphics. Matte black, ls7 TT, decent rims.
Fin
lol
no she will be staying NA
whether or not she ends up getting a full respray of a different colour im yet to work out :cool: i have a few ideas in mind which work so we will see what happens....
matte black FTL lol not the biggest fan of it :D
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
