i had one of those yesterday. f**king InDesign CS4 has chosen not to work, and its actually a legitimate copy!
Not condoning the use of pirate/illegal software of course, but I'd be guessing it would probably work :D
I want a busy weekend... think I'll drop round JIS and see if theres anything I can impulse buy. :P
Bit of automotive retail theropy, definatly works, I love buying sh!t for my car :huh:
A cop was on his horse
waiting to cross the street, when a little girl on her new shiny bike stopped
beside him.
'Nice bike,' the cop
said. 'Did Santa bring it to you?'
'Yes Sir,' the little
girl said, 'he sure did!'
The cop looked the bike
over and handed the girl a $5 ticket
for a safety violation.
The cop said, 'Next
year, tell Santa to put a reflector light on
the back of it!'
The young girl looked
up at the cop and said, 'Nice horse
you've got there Sir.
Playing along with the
girl, he chuckled and answered,
'Yes, he sure did!'
The little girl looked
up at the cop and said, 'Next year tell Santa;
The dick goes
underneath the horse, not on top
peel the rest of it off
you have a nice looking machine, turbo or not. those vinyls shit it to tears
i cant, im sponsered by DZignFX and have to leave them on until next year (feb), but im not sure what ill be doing next year in the sense of going graphics or not
No graphics. Matte black, ls7 TT, decent rims.
Fin
lol
no she will be staying NA
whether or not she ends up getting a full respray of a different colour im yet to work out :cool: i have a few ideas in mind which work so we will see what happens....
matte black FTL lol not the biggest fan of it :D
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
