Here ya go ruby:
[IMG=http://i114.photobucket.com/albums/n273/Damo_s13/Untitled-4.jpg]
anyone else a big fan of dexter? love it! got S1 and S2 at home, almost finished season 1.
About to start it. heard its good.
My fav to date without a doubt is Breaking bad. unreal series. Honestly never seen anything as good.
also watching weeds
Has anyone here installed a Bosch 040 fuel pump into a R33 before? I got so far then got stuck....couldn't actually get the pump and bracket back in the tank. Looking for some help from someone that knows what they are doing.
Edited by Aberax
Damm Nissan quoted me a trade price of $97 for 1 Brembo bleed nipple. :D
Also my front window seal has had it. Leaking water into the drivers floor. $80 bucks for a new one
And replacing my fuel filter which is $30 bucks.
And the RB26 is 3K delivered.
Damm Nissan quoted me a trade price of $97 for 1 Brembo bleed nipple. :)
Get the part numbers, I'll see if I can do you any better
Already ordered the window seal and fuel filter.
Part number for the nipple is #41129S. I was hoping for 10bucks max lol
Might see if a s15 one fits cause i got some at the workshop.
I could do with some new window seals for my car too, how much are they roughly?
Thats not too bad i suppose, i would be after the windscreen, the 2 quater windows, and the rear windows....they look like they are deteriorating, i may replace them if/when i have the whole car resprayed.
also watching weeds
Yeah Breaking Bad is awesome
Cant wait for season 3
-D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
