Got a spare 23k burning a hole your pocket ?????
- Brand New R33 GTR N1 Long Motor
- Fully Assembled
- All Components Brand new
- Ready to Install
- 500PS Package
Engine Package Includes:
- Front Differential
- Sump
- Tomei 1.2mm Metal Head Gasket
- Tomei Metal Intake Manifold Gaskets
- Tomei Metal Exhaust Manifold Gaskets
- Tomei Poncam Type B Camshafts (260 Deg/9.15mm)
- JJR Adjustable Cam Gears
- Sard 700cc Injectors
- Sard Dual Entry Fuel Rail
- HPI Stainless Dump Pipes
- SSI Premium Stainless Exhaust Manifolds
- HKS GT-SS Twin Turbo Kit
- Gates Strengthened Silicone Timing Belt
- Trust Clear Timing Belt Cover
- Nismo Engine Oil Cooler Sandwich Plate
- Nismo Engine Mounts
- JJR Direct Ignition Coil Packs
- NGK BCPR6EIX-11 Iridium Spark Plug Set
- N1 Oil Pump
- N1 Water Pump
- Cooling-Pro Silicone Water Hose Set
- Ceramic Coated Plenum
- R34 GTR NUR Coil Cover Emblem
- HKS Oil Cap
- New Genuine Nissan Air Regulator
Engine Internal Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1
Pistons: N1
Conrods: N1
Just Jap
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
I also have some 17x7 rims that you can have for $550 they are copies of the rims i have on my 180 (Volk GT-P's), they have 3 legal tyres on them and one that has to much camber wear. I was going to use the 17's fro track rims but now that i'm fitting a RB25 i'll be going 5 stud.
Here's the pics 17x7's on the LHS and 15x6.5 on the RHS;
Edited by D_Stirls
ruby, malpassi's are know for making the squeeling noise on startup. sometimes from new. havnt had any fail on me, but i wouldnt doubt they do. personally i like aeromotive. has yours got a black or silver top? black is 1.7:1, silver is 1:1
I think my car is the anti christ! Just finished new pads and rotors, gearbox oil, diff oil, engine oil and filter change and a good wash down under the bonnet. Take it for a spin last night to bed the rotors and pads in, and discover i now have another coolant leak! Seems to be coming from around the water pump, that was only put on 10k ago! Hoping its just a loose bolt and not a shagged pump!
yeah i know what thats like
i got a new isc52mm radiator, n1 water pump, racing hose and nismo coolant put in earlier this yr
next day i lose 20% of my coolant via a cracked hose in the heater core (back of the engine, real pain in the arse to get to)
ahh well
two steps forward, one back - always the way with the older cars
-D
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
