How often do you see another blue R32 GT-R? ahahaha
not that often which is why i get a lil panicky when i do :( have had to make the phone call home twice now to get someone to check if its still there to help me chill :banana:
I think I remember Dave telling me to go for Cusco's.....?
yup. cusco or jic.
There we have it. Dave :banana: Cusco
hard not to. cusco > your mum.
and get some decent offset.
Why would you listen to someone who has never owned a skyline??? :(
haha, cause i know what im talkin about...
... occasionally.
For all your offset & suspension needs, PM Scandy :) The fitment guru aha
exactly.
shame im going for a weaker offset with my next set of wheels.
I think JIS have a set of JIC without spring rates listed.... :)
that they do. they also stock brand new jic fas and tar coils.
There are lots Kye. What, specifically, did you have in mind?
Look hard enough and you can find a 32 GTR in need of some TLC.
I know of a 4 door 33 for sale :)
has to be clean, manual but doesnt have to be a skyline or even an import but would perfer it. dont care about mods just has to be clean and no bull shit.
ive spend the last month so far looking at cars which the owners say once i ask the condition, "oh yeah, its only got like 1 or 2 scratches and thats it man!"
drive all the way up to the northern ghetto and find myself looking at a giant pile of bog and shit with wheels.
and already have a 33 4door with a forged 26 init and im bord with it haha
the man has a forged 26 and is 'bored with it'
f**k that, get him a psychologist
theres something wrong with his grey matter
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
