Just heard a dark coloured nissan skyline was used in a hold up over night.
I assume its the stolen 33 getting around.
Yeah ... wonder how the media will spin it?
"Hoons turn to new wave of crime!"
You sure they werent stealing petrol from the tankers :P
sounds like FNF is in adelaide
Quick (dumb) question ...
Where is a good place to buy one of those baffle inserts for JunBL mufflers? (approx 5" outlet)
Ebay? ... or just go to someone like AAA. They should have something in stock yes? :(
just head out to one of the exhaust shops Roo....they should have it in stock if not then they should be able to make one up for you in no time
Thanks Krishy. I just didn't want to waste a lunch break taking a dead end. :(
yeah Dan, not just any RB30, but OS Giken RB30 .... just the blocks alone are $30k .... and he has bought many of them .... still has a brand new one sitting under his workbench under a sheet if I remember correctly ....
RB30 and RB315 Race engines
The ultimate upgrade for your RB26, these complete pre-assembled bottom-end kits are rated to handle power outputs up to 1400hp.
The RB30 features 86mm stroke with a forged chrome-moly crank, forged chrome-moly SCM steel H-beam conrods and forged 4032 aluminium 86mm pistons. It is made using a new Nissan block and specially designed spacer and liner kit. Special features not found in a normal RB26 include an 8-bolt flywheel pattern*, 22mm gudgeon pins and 23mm rod bearing width. Nismo black metal crankshaft bearings are used, with specially designed crank cap bolts. The bottom end is supplied complete with a metal head gasket, specially designed head stud bolts, adjustable timing gears, tensioner pulley and longer timing belt.
The new RB315 features 89mm stroke and 86.5mm pistons for 3138cc capacity. Normal combustion chamber volume comes to 10cc, but specially shaped pistons can also be custom-ordered. The RB315 is built using an N1 block, with the same specially-designed spacer and liner arrangement as the RB30, with an oil restrictor and piston cooler jets already fitted.
OS Giken RB30 $29,900
OS Giken RB315 $31,900
*An OS Giken clutch must be ordered to suit the crank in these engines
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
