i now have a box of stupidly expensive earls bits and pieces to go on the s14. just gotta pic up one more adaptor fitting from outlaw, and 2 90 degree bends from somewhere else and ill fit it all up.
Edited by scandyflick
Did you get it all through Outlaw's Dave?
hey all.
does anyone have an account with motor traders? can get cheap parts?
need 4x hec716 (ls1 coilpacks)
going external setup on the CA18det..
if anyone has hook ups let me know :P
also,
took my car to get some work done/oil cooler fitted. picked up the car and oil cooler lines were cut to "make them fit better (too long apparently)"
once they were cut the workshop couldnt get fittings to go on them so now i have an oil cooler with cut lines and nothing to connect them with..
what can i do? claim them against the business?
cheers
You won't be able to claim against the workshop as they will say that the problem was caused by the cheap lines. if they had provided the parts then you would have a claim. bring the lines to me and i'll get the fittings on them.
Gotta love the justice system.
The police caught the guy who broke into my parents rental property, got locked up but then released on bail a day later. Found out he was released last week on bail for beating a guy up. They can't lock him up for longer as this offence is totally different to the others.
What a load of shit.
Hey guys I have a quick question, I did search and did find an answer but I just wanted to see if anyone has a difference of opinion. If I am fitting aftermarket CF N1 Vents to an aftermarket FG bar, what is the best method of holding them in there?
Cheers :)
nice big plume of black smoke across the northern burbs - pgs (plastics granulating factory) has caught fire in kilburn
i could see the plume from semaphore... 30 metre tall flames as i drove past.... fireys are worried cos there are lpg tanks nearby and folks have been evacuated from their houses... looks like every cop in adelaide is down there
sooooo
go for a cruise if you're bored, they got bigger fish to fry tonite lols
-D
Unfortunately, thats a (fair) case of innocent until proven guilty. Until the court case prosecutes him, any further (accused) offences are to be treated without prejudice. Why cop the second offence harshly is you're innocent of the first offence?
Thats just the way things work.
I know what you mean tho. A close friend was killed in an auto accident by a crim who was on bail for murder at the time. His first offence (altho prosecuted for it) was not taken into consideration in sentencing him for killing my friend. He got 7 months added onto his already 7 years (for murder)!!! So he basically got a freebie before going to jail. FAIL
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
