woot just installed external coilpacks on my CA18det, and wow... soooo much smoother!!
highly reccomend them over splitfires for a cheap $230..
also need one parklife ticket!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by rad32
Just because i drive a 31, doesn't make me poor!
I've known this girl for a while, so its not exactly going to be awkward.
Strand, Salsa, Gringos, Revolving Restaurant seem like good ones at the moment.
i was at the strand last night with 7 other mates. was abit loud but the food was great!
the woodoven pizza was f**king awsome!
revolving restaurant was pretty shithouse when i went there, never been to the other 2 places
Edited by Import S13
if you stopped spending money on the truck, might make it easier to spend money on the 31. :)
had to set it up just how i needed it
plus the weather has been more suited to spending money on my truck :bunny:
i need a females idea on a place to take them.
Guys seem to say Mcdonalds and crazy horse....
Sebel on North Terrace will make her heart flutter. Cross the road later to the Casino to catch a band depending on the night. And Sebel is not as expensive as you'd think it was.
Bombay Bicycle Club has a nice atmosphere too.
bombay isnt bad but they tend to rush you
if you're after some of the best indian food, in the sorta atmosphere that would make her weak at the knees, then try 'Jasmins' in Hindmarsh Square .... I've never had anything bad to say about these guys, and thats why I keep going back..
I think for $45 ea you can have a samplers menu where they bring out small portions of many things - just dont have the tindaloo if you're planning to kiss her hahaha - place also has a stupendous wine list, and the waiters are >extremely< good there - try it, you won't be disappointed by the service...
for thai food, I'd recommend a place called "Khim" on Prospect Road - much cheaper than Jasmins but top quality - has a nice atmosphere to it as well
for aussie themed food, try the red ochre on the torrens - our own chef stagea works there and its one of the few places that serves crocodile and kangaroo
-D
I just asked her if she is allergic to any foods, and she said no, but dislikes Indian and Thai foods.
Daves idea of Escobar, with latin dancing in the background is sounding good.
And the revolving restaurant, with the grand afterwards is nice also..
back from another weekend out at the drags........awesome cars...........awesome weather..........and now a awesome sunburn too :) however got to finally run the 34 a couple of times to see what she is capable of...........cant wait to do it again!
gauchos and escobar > revolving and grand. trust.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
