coz he was in breach position and was compressing up
in wendy's ribs, due to his size.
they usually take them at the end of the 38th week with c sections anyways.
Yup that'll do it lol!!
Glad things went well! Definatly an eye opening experience isnt it, lucky you didn't have to go through the tradational birth stuff first!
Hell, while you're there, why not! :bunny:
That's my way of thinking!
just thought id pop in to make a little announcement,
our new baby boy, Lachlan James was delivered by c section at 2.45 pm yesterday,
at 38 weeks he still weighed 9 pound 8oz and 51 cm long,
both mother and baby doing very well!
cheers!
:P
Damn good news mate! Glad to hear all is well!!!
so whos interested in paintball? I wanna organise one closer to christmas or just after, when the weather gets a bit more predictable.
Farkkkk Yesssss to paintball!!!!! :bunny::P
Andd big congrats to craig for the new addition to the family and hopefully future sau member hehe!!!! :P
Edited by wnted1
Woo Valiant starts :( After 5yrs of it sitting there it starts woo.
Anyone know what oil filter they take, what oil is best, what spark plugs and what coolant is good for it?
James im looking at you lol
Finally had a chance to head down to Regency and change over my rego on the V35 today. Hooked up some nice plates for it too (well I like them) .... have to wait 2 weeks for them to be made though.
Also fitted some goodies incl. Nismo rad cap, Nismo oil filler cap, and Carbon Fibre bonnet struts - they are bloody awesome!
Congratulations Craig!
And Pete, its just i know a guy with a fairly potent VH Pacer 6 Pack, and know there aren't or were too many floating around. This thing embarrassed many an exotic owner !
congrats craig! :)
wheres the cf cover?
and what plates did you get?
Wow. These XD9's are a very expensive porch ornament.
this surprises you?
Ahh OK.....if it's got a cut & shut Customline 9" rear end then yep, it's my old ride
Woo Valiant starts :) After 5yrs of it sitting there it starts woo.
Z9 Filter if it's a 225, 245 or 265 6 cylinder, which is actually the same thread as RB's use but a lot bigger.
Our old dirt circuit Open Wheeler was running a Jeff Juring built 265 HEMI making around the 350HP mark.
Edited by D_Stirls
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
