oooo... fabrication of sump extension almost complete, short block almost complete!!! =D
just need to sell my PFC, anyone?
How much haha? Swap ECU's + cash your way maybe if the price is right although I'm not really fussed if I keep the standard ECU, plan on keeping mine as is really and just maintain its cleanliness
Awesome video for all you GT-R lovers;
Z9 Filter if it's a 225, 245 or 265 6 cylinder, which is actually the same thread as RB's use but a lot bigger.
Our old dirt circuit Open Wheeler was running a Jeff Juring built 265 HEMI making around the 350HP mark.
Ahh, have always had a soft spot for those Hemis....do you recall what was done to it Dale?
We had a cam grinder and used to put our own profiles on the cam lobes with various masters to choose from in the cupboard, then get get them nitrided.
Messed around with the hydraulic lifters in those things and turned them into solids just so we could get ridiculous lifts, durations & overlaps that'd shake the whole car on idle...strictly for drags though.
Go swimming in the 4wd did we Matt haha
seems one of my last escapades where i had the bottom of the doors below water level by at least an inch and a bit was the icing on the cake. splashed water up inside my door, got into my high/low pass filters (that were mounted in the stock speaker location high in the door). Was alright until i re-fitted the tweeter that had fallen off, which killed the filters i reckon
managed to kill both tweeters as well (were reading 1ohm)
Congratulations to Craig for the arrival on the new one mate
so whos interested in paintball? I wanna organise one closer to christmas or just after, when the weather gets a bit more predictable.
Definitely interested
:D This is gonna sound pretty gay. But for some reason Damo, You were in a dream of mine last night. And you drove a VT commodore.
Yep your right it does sound gay
Yeah, i only tuned it to 10.5psi to increase the life of the turbo. 12psi is at peak efficiency for a stock rb25 turbo.
I have been running on 12 psi for almost about a year now Damo and the turbo was still going strong making 214 odd so rwkw.....for 10psi i think that figure is quite low mate.....as i remember making 180rwkw on 7psi....hopefully whatever it is you can get it sorted out mate
there are times (not many) when the north scares and confuses me.
example, on my way home from a 31 club meet, just drove past elizabeth, about 30 seconds away from my intersection, and im sitting behind a vz commodore, both of us sitting just over the limit, and the rear passenger of the commodore decided walking might be a better way to get home and throw himself out of the car.
onto the asphalt.
at 90k's an hour.
without a shirt on.
so both me and the commo throw on the skids and stop, i jump out and run back to the guy, the 2 other blokes in the commo do the same, we get to the guy, hes got blood all over his face, his back and arms are all cut up, and yeah, blood everywhere. and the 2 blokes just throw him back into the car, thank me for stopping, and drive off in a casual way as if all is fine and f**king dandy. f**k.
Just like any other night out for these guys :)
At least the bloke was considerate enough to leave the booze and ciggies in the car before bailing! :)
I lived in Lidabeff during high school ... feral as! :P
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
