Dan, that is the poorest excuse ever :).
Does anyone know the exact way to get the dash out so I don't have to remove parts that dont need to be removed, I am changing dash lights and the lights that go where the hazards are etc.
Quick little tip?
Cheers :).
Edited by Weezy
I meant Inline6 Haha.
But your keen, good good. Jenkies Keen, Mad.
3 of us makes for a nice little group.
I am not mad keen on a full on hillzy touge spec my rear tyres have inner wear like a madcunt but I am keen on heading out.
Dash removal - R32 - How :).
cool so chronic wheezy inline6(is a pussey)
wheather is lookin a bit pooey anyone know if its gonna be a clearer night tomorrow. this is starting to look like a 32 gtr fest so possibly try and get as many 32 gtrs together as possible and head out tomorrow night??? get some photos :)
I had actually already planned to meetup with a few other mates aswell for tomorrow night I can't ditch them and be like 'Sorry guys, hanging out with RB26 crew' haha.
If it stays clear tonight Jenkies I don't see why not tonight haha
Dan, that is the poorest excuse ever :) .
Quick little tip?
Cheers :) .
Did this a couple of weeks ago, remove about 4 screws on the top of the drivers side panel under the steering wheel, pull it down ever so gently as to see about another 4 screws under that holding the bottom of the instrument surround in, then 2 screws up the top and 2 screws, one under the headlight switch, one under the wiper switch. Remove the surround (be REALLY careful, 16+ y/o parts can be brittle!) then unplug cables. Instrument cluster is 4 screws and it will pull out + remove plugs behind.
EDIT: Im slack, its probably better to remove the lower panel all together, its an additional 2 screws down the bottom on the left hand side, 1 one the side where the door closes with a little dome cover over the top and 2 screws behind the bonnet release.
Found this aswell: http://www.skylinesaustralia.com/forums/R3...html&hl=r32
Im easy for tonight or tomorrow night aha,
Whatever it may be I dont care.
Either Zillafest as the man says tonight, or all car tomorrow night :).
Almost finished my LED instal haha, my finger tips hurt from trying to get plugs out :).
So much of the dash needs to be pulled apart on a 32, give me a 33 to do anyday ahaha
Nah I found it quite easy. I ended up replacing the entire front section of the interior anyhow (after I'd fitted the led's) so I had to take it apart again, and then had to do it a third time to fix the airconditioner actuator
-D
I went to change my demister globes etc and the socket types are totally different to what I got sent to me from ZeroPoint Electronics?
I don't know, I'll PM him and see how the eff they're meant to work lol.
Anyone cruising tonight or we gonna have a bigger meet tomorrow night?
Take the LED out of the holder he gave you and the globe out of the rubber thing found in the switch. Then cut down the rubber thing (because the LED's wires are shorter) and thread LED wires through, wrap around so the base looks like original but shorter and with an LED. Easy.
Are you doing your climate control? Thats trickier than the switches.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
