balls. internet is running so f**king slowly. but ive got 8gb left til i hit my cap apparently.
cleared history, cleared cookies, reset router, still running slow as all shit. any ideas?
Sync speed & snr?
Grab a test file to see what sort of speeds you're downloading at, if your ISP doesn't have any grab one of internodes http://mirror.internode.on.net/pub/test/10meg.test
hmm - wilall told me they wernt interested in tuning the stag
Thats funny. I was told some weeks ago to bring mine in for a tune because they have their new 4WD dyno. ;)
i wasnt asking wilall for a tune, was asking their opinion on a problem...?
Sync speed & snr?
snr?
downloading test file at the mo.. 6kb/s. fail.
Modulation on router on the correct setting?
can i get that in computer stupid? (aka, english)
Edited by scandyflick
You can access that setting in the routers home page... usually found at 192.168.1.1
If your on adsl2+ usually the modem/router likes that setting better than mmode or gdmt. Might not be the issue either.
Incidentally I'm surprised moderators haven't stumbled across the threads in the ' General Automotive Discussion' section of the forum..... LOL!
yep, thats pretty bad.
You can find yor sync speed in the modems config pages too, normally under something like statistics/line settings
If you're syncd well above 6kbps then it's time to call your isp to see wtf is going on, could be backhaul issues or incorrectly shaped, if the sync speed matches the download speed then it's also time to call your isp and lodge a line fault.
Which ISP btw
adelaide blows. had a friends going away party tonight. got refused from 2 venues ive never been to before because my footwear 'wasnt up to standard'.
are you f**king kidding? how the f**k can a glorified pub have a goddamn dress code? sorta killed what was shaping up to be a decent evening.
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. ;)
Coz he's a batty boy amiright?
Anyways,
Going to look at this white GTR monday with Weazy (if he can make it). If that doesn't all go to plan Jenkies is going to be without a GTR.
At 6k a second he'd be using ANSI modulation - which is unsupported by most ISP's.
G.DMT is the standard modulation type for most, ADSL2 and 2+ have their own modulation extensions, such as Annex M and the like.
For what its worth, I'd turn the router off for 30 minutes and then turn it back on - sometimes that will cause the exchange to do a full retrain on the adsl synch when it comes back online...
And the router can generally be found by opening up a command prompt and typing ipconfig /all - whichever is your default gateway is usually the modem router (unless you have a windows or linux gateway)
-D
all this computer talk is nuking my brain...
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. :cool:
haha, probably. sounded a bit sus to me. f**kin ruined my night though.
Fashion Police are at it again.
What shoes did they refuse?
What's he gonna do if he gets bashed in the streets
He ain't a bouncer he's just the fasion police
good song haha
funkoars f/ hilltop hoods - What I Want
welp, found out why my internet sucks.
its cause adam sucks.
they apparently cap uploads aswell. balls.
think ill move back to internode.
shits gonna be frustrating for the next 12 days.
yeah , they count your uploads.
Adam are shit, they overload their rim's causing shit speeds and reliability.
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
