Your ride height is far from low
if i had stiffer suspension it wouldnt bottom out.
these bilstiens, while being hard compared to std shocks, are spongy
writeoff can attest that when i was going to moonta last year, we'd hit a dip and my entire exhaust would bottom out on the tarmac and shoot a tonne of sparks, so much so that it ripped apart one of the welds on my muffler
its not about how low it is, its about how the ride height interacts with the suspension - i'd be fine if I had totally stiff suspension but thats not the case
-D
Need coilovers
would be nice, but i need something thats street legal - got any tips on something that
a) rides nice on the street
b) is legal (or can be engineered)
c) is firm enough to handle well
d) doesnt bottom out
I got bilsteins atm but theyre the basic version (and probably getting long in the tooth)
If it wasn't an issue of legality I'd just buy the ISC coilovers and be done with it
-D
*plugs antenna back in*
Safe to assume an 02 sensor shouldn't be doing that an its probably farked?
/noob
Thanks!
Well actually yes that's what a narrow band O2 sensor will do when the engine is in closed loop mode. If you look at the voltage output from a narrow band sensor there is a big difference in the voltage between 14.6 and 14.8 and all the ECU does is aim above till it gets a low voltage and then aims below until it get's a high voltage, so by constantly going above and below it averages 14.7 which what we are looking for.
-D
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :laugh:.
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :(.
hey Dave i hear your car is looking heaps good now
can you pm me some pics ? :3
lol. its looking fully reasonable.
havent had a chance to take any pics yet though (only got it done yesterday), but ill be out taking a few snaps tomorrow night. so stay tuned.
awesome, my mate saw you drivin the other day , i look forward to seeing images! :ermm:
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :ermm: .
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :) .
ahh brew ur twisting my arm eh brew
ok, are they off your car? I might see if my mechanic can fit it next week for me to test - I'll take it to and from loxton with your permission
-D
manage to find all my stock parts for my suspension. Hopefully i can get it cleared by the end of next week.
Main thing im worried about are the gauges, and fitting up a brake light to the rear window.
Yeah they're from my car man.
I don't see a problem with you taking them to and from Loxton, I'm sure someone has some details about you incase you do a runner - LMAO
*points to trader rating*
and sled knows where i live haha
-D
can I ask what steering wheel you had and what reason theyve given for it being illegal?
-D
I have a rear window brakelight out of a 32-R that you can borrow if need be. Ive been too lazy to put it in mine. Only need power and double sided foam to make it work.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
