Your ride height is far from low
if i had stiffer suspension it wouldnt bottom out.
these bilstiens, while being hard compared to std shocks, are spongy
writeoff can attest that when i was going to moonta last year, we'd hit a dip and my entire exhaust would bottom out on the tarmac and shoot a tonne of sparks, so much so that it ripped apart one of the welds on my muffler
its not about how low it is, its about how the ride height interacts with the suspension - i'd be fine if I had totally stiff suspension but thats not the case
-D
Need coilovers
would be nice, but i need something thats street legal - got any tips on something that
a) rides nice on the street
b) is legal (or can be engineered)
c) is firm enough to handle well
d) doesnt bottom out
I got bilsteins atm but theyre the basic version (and probably getting long in the tooth)
If it wasn't an issue of legality I'd just buy the ISC coilovers and be done with it
-D
*plugs antenna back in*
Safe to assume an 02 sensor shouldn't be doing that an its probably farked?
/noob
Thanks!
Well actually yes that's what a narrow band O2 sensor will do when the engine is in closed loop mode. If you look at the voltage output from a narrow band sensor there is a big difference in the voltage between 14.6 and 14.8 and all the ECU does is aim above till it gets a low voltage and then aims below until it get's a high voltage, so by constantly going above and below it averages 14.7 which what we are looking for.
-D
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :laugh:.
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :(.
hey Dave i hear your car is looking heaps good now
can you pm me some pics ? :3
lol. its looking fully reasonable.
havent had a chance to take any pics yet though (only got it done yesterday), but ill be out taking a few snaps tomorrow night. so stay tuned.
awesome, my mate saw you drivin the other day , i look forward to seeing images! :ermm:
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :ermm: .
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :) .
ahh brew ur twisting my arm eh brew
ok, are they off your car? I might see if my mechanic can fit it next week for me to test - I'll take it to and from loxton with your permission
-D
manage to find all my stock parts for my suspension. Hopefully i can get it cleared by the end of next week.
Main thing im worried about are the gauges, and fitting up a brake light to the rear window.
Yeah they're from my car man.
I don't see a problem with you taking them to and from Loxton, I'm sure someone has some details about you incase you do a runner - LMAO
*points to trader rating*
and sled knows where i live haha
-D
can I ask what steering wheel you had and what reason theyve given for it being illegal?
-D
I have a rear window brakelight out of a 32-R that you can borrow if need be. Ive been too lazy to put it in mine. Only need power and double sided foam to make it work.
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
