Playing with the new PC box for my surveillance last night. Took a bit, but got it working. Then I find out its not accepting my password to configure the software. I definitely wrote down the password when I installed the software. Time to reinstall the software and try again! Tonight I'll plug in the cameras and see how it performs. Next I upgrade the cameras and log in over the internet, so I can watch my f**king dog misbehaving from work. :huh:
200's almost there. just gotta put the airbox, inlet, and hotpipe back on. well, that and a couple new dump pipe studs >.<
lost a couple nuts for the airbox, so ill be heading down to coventry's to get those soon, if all goes well, it should be fired up and driving for the first time since ajd this afternoon. awesome.
Saw the latest Rapid mag and saw the turboed Brutale. Madness :rolleyes: The engine has no bottom end revs to begin with ... reckon it'd be too laggy.
I'm selling the Brutale now anyway. Putting the mighty TLR back on the road, and over the next couple of months customising it a bit more :blink:
dude if you EVER want to part with the TLR plz hit me up ey
:P
which one????
nearest one is salisbury.
depending on what size, motor traders have a small range of nuts and bolts....we dont have a minimum....unless its eftpos...then its minimum $10
the ones im after are pretty common me thinks. got small bolt in the same thread i need, just need a larger one, and a couple nuts, id be surprised if they dont have them.
oh yeah, dump pipe. :rolleyes:
tis awesome.
Edited by scandyflick
:P
I have thought about it ... but it almost tore my guts out.
But that day may come one day. I do already have a list of mate's who want it (and would kill me for it :rolleyes:) but I'll keep you in mind, in case I see a new toy I want.
Nugsy, you might recognise the TLR like this when I use to drag race/track day it ... just before I got my drag bike built.
This was before all the good stuff went on :blink:
Edited by RubyRS4
i can send an email down saying ur my cousin and to do you good deals if your goin down that way if you want
yeah keep me in mind in 5yrs time if you part with it.
always wanted a v-twin, and the TLR would suit me nicely
mind you, an rsvr aprilia Mille or honda sp1/sp2 would be interesting as well
meh atm, sciatic nerve rhs is real bad, can barely sit down now after 10days
one year tho I'll get back on the road.
thursday is dynotune day............ yay
Guest
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
