i see you were lucky enough you got your comment published... mine got rejected as usually and it was pretty much only what i wrote in post above  :)
they usually only accept comments supporting their side of story... and i thought newspapers were not supposed to be biased...
seriously, just about anyone could become journalist in australia looking at quality of journalism here... hoon stories in advertiser and bra stories on ACA seem to be australian journalism at its peak...
the message here is if you are a retard that repeated every school year 3 times, failed at just about anything, dont have any qualification/education whatsoever but are not in physical shape to do anything with your hands: become a journalist or a cop... or maybe a road safety minister
You can also be all these things and still get a license to drive a car...
i know theres alot of well knowledged people here on turbos...mine shat itself this arvo....ebay special "team badrun" T04e with internal gate and v band thingo.....im looking at the monsta brand atm
http://cgi.ebay.com.au/MonstA-T3-T4-INTERN...%3A1%7C294%3A50
this is exactly what im looking for and pretty much what i can afford....any ideas???
dont do it Ben monster turbo are shit, see Bill at adelaide turbo services and get yours rebuilt
what do you reckon it would cost roughly???...by the look of it, its the rear oil seal.....maybe i could get mine hiflowed as well... :)
Cara, don't do this DE+T bullshit. First it will never be legal, emissions will be totally different to a DET motor so you will have to rip all the shit out if you get defected. Second, the motor just isn't up for it. Bite the bullet, buy a DET and be happy
Guest
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
