zzzzz
im off to Melbourne tomorrow :)
only reason i could justify i trip down is to get money off grandparents for my bday and xmas and then go buy myself an RB25DET -__-
cool you will notice a good power gain there mitch over the DE ;)
yeah , cheers for the advice allan
now to raid someones credit card >_>
also , how hard would it be to put the engine in my self with a mate or two
and obviously get a tune up after its been put in
178 for wanlis is cheap? i cant remember how much i used to pay for them, thought it was less than that though. Kye, if you want new, go see graham at bob jane modbury, lauren should be able to sweet talk him lol, otherwise tell him i sent you down there or i can ring him and tell him your coming in and to help you out with what he can. Did the same for Eddy last week.
so you wont need to get it re-tuuned then, which is impossible any way....
sam, i go to fitness first holden hill, used to be a body builders gym, si its hot loads if equip.
you?
i was going to viva fitness at findon last year, but finished my membership and now i lift with my mate, hes got a bench setup and all that.
was thinkin of going to fitness first awhile back, i hear they have a pretty good facility
thanks luke :) ill be getting pretty messy at mawson lakes hotel sat night
any one feel free to come!
dan, ryan came round today, but we snapped a turbo stud, ;)
got captain thread comin out tomoz, then ryan is comin back to finish it off
Guest
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
