Half cage is legal. I'll get the section from the ADR handbook in a sec.
From memory, it must be padded and you must re-register your car as a 2 seater, but I'll look it up now.
Edit: and get it engineered, and carry the paperwork with you. But either way, cops wont have a clue and will defect you even if you show the engineers report.
Edited by CRoNic...
can anyone recommend anygood places to get roll cages made up that are road legal, cauz i wanna get a drift car biult up, and still have it legal for the road.
cheers... michael p.s guess its gunna be an expensive sport but, seems like poeple are getting into it, oww luke(orgzmc) do you know much places to get good parts and what i need for it, im thinking of a 180 or such.
Alright here's a quote from what the act says:
Roll Cages
Due to the increased risk of occupant injury in vehicle accidents the fitting of full roll cages are not permitted.
However, the fitting of a roll cage rearward of the driver is permissible providing that:
a. No part of the roll cage is contactable by vehicle occupants when positioned in their normal seating
position.
b. The roll cage is at least 150 millimetres rearward of the front seat occupants when the front seats are
located in the most rearward adjusted position.
c. All rear seats and seat belt assemblies fitted in the rear compartment are removed.
d. The operation and effectiveness of the front seat belt assemblies is not affected in any way by the roll
cage.
e. That no person travels in the rear of the vehicle at any time.
-dstroy u plan when and when you not gonna need it :D i think i might go roll my car
on a unrelated matter the 1 benefit of police attention on cars is i can skate freely where eva the hell i want, gone are the days i used to get 30 min leatures of pointless dribble and friends getting $50 fines. was skating down jetty rd went past a cop with time on his hands and nope didnt even so much as look at me. love it ;)
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :P
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
Not sure if it's illegal but I wouldn't recommend running no cover, if a stone gets kicked up from the road and comes into contact with the timing belt and causes trouble, things could get interesting. Just buy a clear cam cover then you have protection and can still see all the pretty stuff
hey all, just wondering if anyone knew if you can put gtr injectors into a 33 gtst and if so what els do u need? eg resistor packs
i do believe its a no go... they only fit on rb30 an 20 from wot i'm told...
rb25det are side fed, rb25det neo is top fed and rb26, rb20 are top fed
it could be done but there needs to be some modifications to the rail, collars etc best bet is to just go with side fed sards or nismo injectors
http://www.news.com.au/adelaidenow/story/0...5018092,00.html
For everyone who hates the human colostomy bag known as Amber Petty.
-D
Cruel but funny: 9% (60 votes)
Tall poppy put-down: 7% (50 votes)
Hurtful and uncalled for: 10% (65 votes)
Total rubbish: 14% (93 votes)
Spot on: 58% (372 votes)
HAHAHAHAHAH
Edited by AndrewJZX100
Guest
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
