Pictures taken from a persons front yard, Dean st 9 October 2007 -A guy driving a Nissan Silvia, just after dropping his mum and sister off down the road, hit a tree, split in half, the front of the car landed in the middle of the road, the back end landed in the front yard of the house across the road. He was still strapped in in the part of the car that landed in the yard. - The battery from the car flew all the way up to the Kerrigan St roundabout, (about 50mtrs up the road)
Would you believe, he got out of this with a mark on his arm (possible fracture) and a bump on the head!
But here's the kicker, The car wasn't his... it was his roommates, and it wasn't insured!
This guy better be thanking his guardian angel, cuz he was sure looked after today!!!
1st pic, the front of the car
2nd pic, where the back end of the car ended up
3rd pic, on the tilt tray
4th pic, the tree he hit
plus other close up pics
https://www.sau.com.au/forums/topic/188827-silvia-in-rocky-bites-the-dust/
  • Replies 46
I didnt take them, just got them in an email, thought I'd share.
People are their own worst enemy, plain and simple. I remember an incident that could've easily ended up like that if I had been 1mtr to the left or right of a couple of poles sticking out of a traffic island. I was lucky to walk away from it, and so was this guy. Lets hope he learns from it.
wow the way that cars split, lookin at those pics, i'd be thinking it was cut n shut before. doesn't look like it was a huge hit, yet the car's in two.
thats what I am thinking the break is far too straight to not have been welded there before!
isn't that how they make silvia's?
Silvia - 180 - Sil80 - Onevia
they're just pieced together like mechano arent they?
yeah the panels are bolted on and off....not cut trough the chassis and welded back together!
i wouldnt be so sure it has been cut and shut before, i mean u have a very large % of the weight at the front and if u hit it in the right spot i wouldnt be suprised to see it look like that.
Ive seen pics of an enzo (diff ball game entirely i know) but it was split cleanly in half and i doubt it was cut and shut :w00t:
anyways f*k that, atleast no one is dead tho
fraken hell.
how can you even get a siliva up to those kinds of speeds1!!!
lol.. the SR20 is a better motor than the RB20 how does a R32 get up to them speeds bah...
lol.. no the panels are switched over.. acutally to chance a sil to a onvia u only need philips head solder tin snips 10mm spanner and sockets.. takes around 2 hours to do.. same thing to do the sil80.. :w00t:
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
