Pictures taken from a persons front yard, Dean st 9 October 2007 -A guy driving a Nissan Silvia, just after dropping his mum and sister off down the road, hit a tree, split in half, the front of the car landed in the middle of the road, the back end landed in the front yard of the house across the road. He was still strapped in in the part of the car that landed in the yard. - The battery from the car flew all the way up to the Kerrigan St roundabout, (about 50mtrs up the road)
Would you believe, he got out of this with a mark on his arm (possible fracture) and a bump on the head!
But here's the kicker, The car wasn't his... it was his roommates, and it wasn't insured!
This guy better be thanking his guardian angel, cuz he was sure looked after today!!!
1st pic, the front of the car
2nd pic, where the back end of the car ended up
3rd pic, on the tilt tray
4th pic, the tree he hit
plus other close up pics
https://www.sau.com.au/forums/topic/188827-silvia-in-rocky-bites-the-dust/
  • Replies 46
I didnt take them, just got them in an email, thought I'd share.
People are their own worst enemy, plain and simple. I remember an incident that could've easily ended up like that if I had been 1mtr to the left or right of a couple of poles sticking out of a traffic island. I was lucky to walk away from it, and so was this guy. Lets hope he learns from it.
wow the way that cars split, lookin at those pics, i'd be thinking it was cut n shut before. doesn't look like it was a huge hit, yet the car's in two.
thats what I am thinking the break is far too straight to not have been welded there before!
isn't that how they make silvia's?
Silvia - 180 - Sil80 - Onevia
they're just pieced together like mechano arent they?
yeah the panels are bolted on and off....not cut trough the chassis and welded back together!
i wouldnt be so sure it has been cut and shut before, i mean u have a very large % of the weight at the front and if u hit it in the right spot i wouldnt be suprised to see it look like that.
Ive seen pics of an enzo (diff ball game entirely i know) but it was split cleanly in half and i doubt it was cut and shut :w00t:
anyways f*k that, atleast no one is dead tho
fraken hell.
how can you even get a siliva up to those kinds of speeds1!!!
lol.. the SR20 is a better motor than the RB20 how does a R32 get up to them speeds bah...
lol.. no the panels are switched over.. acutally to chance a sil to a onvia u only need philips head solder tin snips 10mm spanner and sockets.. takes around 2 hours to do.. same thing to do the sil80.. :w00t:
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
