Hey there, if anyone has 19" wheels on there R33 GTS25t I was just wondering how it effects the cars performance as in handling & grip etc..
I'm concidering purchasing a set of 19" rims but I'm worried about scrubbing, rough & bumpy ride, excess stress on bearings, bushes etc.
My car is a daily driver so I want it to be very pratical & not unberiable to live with day in & day out.
Currently I have some 17x7 with 235x45 bf goodrich tyres on stock suspension & the car is just fine as a daily driver although I could go a little bit tighter on the suspension. If anyone could give me feedback it would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/188878-19-wheels-for-r33-gts25t/
I had 19's. THe ride was a tad rougher. Nothing to write home about
Right about the tyres being super expensive though for anything decent. Didnt relly notice a different in handling and it wont scrub if you get you measurements right.
"How will 19" wheels effect performance?"
negatively. more unsprung weight means poorer handling, worse acceleration and the standard suspension will have trouble controlling them nicely. of course they are also illegal. personally I think it's a bad idea all round, but if you must have 19s for some reason then go for it. I mean it's not like your whole car will fall appart instantly, but there are certainly negative effects.
What do you recommend to be the best set up? 18's?? Keep in mind I was considering upgrading the suspension but this brings me back to what is the ideal setup for grip and street use? I'm not really interested into turning my car into a drift machine I'm more set on having a responsive grippy package so the car is more of a pleasure to drive.
I have found some places in the U.S that will sell & deliver 19" tyres or most size tyres at a more than reasonable price, since the oz dollar is so strong the US prices are hard to look past.
na... wont hurt. i had 17inch volk rims with stock struts, stock suspension and stock compressed springs and i have upgraded to 20s. hasnt in anyway affected the cars performance or handling, but it would pay to stiffin suspension with some shorter shocks and sport springs, car tends to scrape the inside of the front wheel wells when hitting dips on the road. also when putting rims on the front you wouldnt be able to slide a piece of paper between the wheel and the struts hehe!. 19s should fit no problem in the back and as far as the front goes selecting the size of the tire will determine if you will scrape on the inside of the guard knowing you have stock suspension gears...
I would go for a 245 or maybe 235, 35 profile for the front. I was looking to upgrade the suspension with something a little stiffer and just a tiny bit lower but I still want a comfy ride. I think there is more to gain from installing thicker swaybars and strut braces and trying to reduce the roll. Does anyone know what is a coil over that is good for road use?
Does anyone know what the correct offset for 19" wheels are so that there wouldn't be any issues?
If 245 were too much for the front then I would go 235. I currently have 235 on my 17x7 at the front and these have no issues what so ever.
i got no issues with 245 on the front. The 33 guards a quiet big to fill. i can full lock no probs, saying that though.. if a hit a nasty( real nasty) bump it scraps a tiny bit, but nothing that is of a real concern.
Edited by jake33
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
