  • Replies 49
If you go onto http://www.powerplayimports.com/includes/c...php?make=Nissan The Ztune is still for sale and i rang PowerPlay and the said it was still for sale $250,000. Hear are a heap of pics to......
http://www.powerplayimports.com/minigal/in...TUNE&page=1
Be nice to have that kind of coin.
The 72 GTR clone looks nice too.
Why would anyone want to modify it anyway? you'd have to think you were smarter than the nissan engineers if you thought you could improve the car just by changing the exhaust or completely redoing the engine management. All it will achieve is you will ruin the driveability and lose your factory warranty (i presume it has warranty).
Everything about this car is only awesome when it is all as nissan designed it. :P
Edited by pixel8r
I guess the guy was full of shit then.
Is it me or does the red interior look kind of 'shit'?
Yea I dont mind the red on the seats with the leather but the only thing thats a bit of is the steering wheel just looks a bit to new for the car...
much prefer the standard gtr wheel. but i would never change it i would leave it how nismo wanted it hey...
100% agree mate.... 10.1 sec quarter mile any faster and it would't be street legel anyway... :P
hmm that guy seems a bit quiet... i call bullshit as well. as for the whole modding thing. DONT DO IT. not on a car that is 1 of 20 IN THE WORLD (and as far as i know 1 of those is still at the NISO factory). why would you change anything on a car that was 4 years in the developing, as has stats that will blow away any other manufactured car. period.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
