grab an rb25 front compressor cover and bolt it on.
if thats not an option then get a 90 degree silicon bend from anywhere that sells them or get someone to weld a 90 degree steel bend onto the vg30 front cover.
You would have to check this (not at home to look at my R33) but don't 33's have an elbow bolted to the compressor covers outlet ? Not certain but reasonably sure that the RB20's ceramic BB turbos housing has a three bolt outlet but the holes are on a slightly smaller PCD than the RB25/VG30 BB turbos housings . If you can find one the RB25 elbow possibly bolts to the VG30 comp covers outlet .
Hope this helps , cheers A .
yeah the rb20 elbow has a slightly smaller pcd. as a quick fix so you can get it running untill you can source something else. you can drill out the rb20 elbow bolt holes to a larger size untill you get the bolts to pick up in their threds.
i had to do this untill i got a rb25 elbow when i put a rb25 turbo on my rb20. its not ideal but it doesn't leak and gets you going.
Thank you all very much for you help. Just going to use a 90 silicon bend for now but might change that in the future.
Huddy: Its killing me man, everytime I go to do something there is some other issue that I didn't know about. BUT I am getting there and I will be a VERY happy little chappy when its going. I just hope its sooner rather than later.
  • 1 month later...
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
