its the same staff as a patrol so dont fall for that oh its an import its really expensive bs
sounds like the plastic thingy inside is broken has happened on every car ive owned that had an electric antenna easy job to replace just need a new staff
heh my antenna just popped out by itself one day when I started the car. When I tried to put it back in the motor grabbed the track and pulled it down, but doesn't seem to grab enough or pull it down far enough as the antenna is still unstable and falls over pretty easily. So for nearly a year now the antenna has been in the shed and I just listen to my CDs as the radio is always crap. Anybody know where I can get it fixed NOR for a relatively cheap price? I never bothered getting it fixed before because I thought it would be ridiculously expensive, but by the sound of these posts it shouldn't be... although I've got to pay rego soon :rofl:
Don't bother getting it fixed. Strathfield will fix it for something like $150 to $200. Just buy the whole thing off a wreck. It comes as one unit. You can install it yourself, shouldn't take more than half an hour and should only cost about $20. If you really have no idea how, it sounds like there are a few people on here... including myself... who have done it before, so someone can give you a hand.
Apparently i ain't the only person who got their antenna snapped off by some ahole. It's a piss of a simple job actually, i replaced just the antenna portion for a camry (back home), took about 45min to an hour, I'd imagine replacing the whole assembly being even easier.
Gavin, the antenna assembly is the same as the nissan petrol's ? I should go scout for one soon. Cheers for the info.
Sorry to steal the thread but I have an antenna related problem, I have a R32 and the radio reception is crap to say the least. I have had a look at the connection behind the radio and also the one that connects to the antenna but nothing seems wrong.
Anyone got any suggestions.
I would fix it myself but I've got no idea how to get to the assembly, my searches on this site and google for any info turned up zilch.
If you get another assembly with antenna, I'll help you fit it. :D You have to take your jack out, as well as the brace that the jack fits in. From there you have to loosen all the bits that hold the assembly in as well as a wire holder. You have to pull the whole thing out and un plug the cable and pull the drain tube out. Then to fit in a new one, just do everything in reverse. :P I'm happy to give a hand on a weekend if you need.
Aren't R32 antennas a part of the windscreen? It is built in the passenger side of the windscreen or something.
Thanks for all the replies guys much appreciated...yea went to strathfield and the dude said that its more likely that the mast (i think that how its spelt) is stuffed and needs replacing cause i can still hear the motor running, no need to replace the whole unit. So if i could find a replacement aftermarket one would be great...might check out the Nissan Patrol ones (thanks GWPO21 for mentioning that) or off to the wrecker i'll go.
Now to pull out the old one out, will try and follow R33-GTS instructions, but do i need to remove any panels? Can i visibly see all the parts when i'm pulling it out?
Thanks again :P
Thanks for the offer R33-GTS, but I managed to take out the assembly quite easily using ur little mini-guide. You don't need to remove any panels Impulsive GT, there are two gold screws towards the top corner closest to the back of the boot... those are holding the assembly in place so after removing the jack housing that's what you need to get at (after removing the antenna controller that's held by a single screw).
I took the assembly apart and fed the antenna track through properly and put it all back together, put it back on the car and tested it out. The antenna still popped out, so I took the assembly apart again to have a look and it was feeding the track through properly like it should. I think my problem is that the little silver top (on the outside of the car) where the antenna comes out has rubber on the inside, which I think is supposed to stop the last section/rod of the antenna from coming out. The rubber on mine looks a little worn out though so the whole antenna rod comes out.
Where can I find R33 wrecks so I can get this part? I've never been to a wreckers before and I wouldn't know which in Perth would most likely have R33 wrecks.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
